Hello All. I have 2 questions and I am relying on all of you to help a brother out. Is there a crossover for the steel clutch plates or is OEM the way to go? My other question is, does anyone else have the problem of the kickstand hitting the bottom corner of the sideplate? I found a fix on here to keep the stand down but not to fix the smashup problem. I have tried to bend the plate flat by gently warming it in the oven but it bends back enough so it really doesn't work. Is grinding a bit of the foot away an idea? I am fiddling with putting a washer in the sleeve of the stand that is on the frame and maybe putting some JB weld on it so it will stay put. Is this ok? Any better ideas? I'm all ears. Thanks.
