Dual Sport an '07 EC300
jyellard
Does GasGas sell a kit with signals, horn, lights, controls, to convert the US EC's to the Euro street legal EC's. If not what is the easiest way to make convert to street-legal?
I know I have some wires tied up in my airbox, but I haven't bothered comparing them to a schematic. Are those just tail-light wires or signal wires also.
Are the signal and horn wires included with the handle bar controller, so I just have to plug power to the controller and then wire the controller to signals and horn?
Thanks,
Josh
Thanks Hydrodog.
I was hoping to buy the components and install them myself. I guess I'll have to compare existing wiring to the schematics in the manual to see what wiring is already in place.
Canada does as well. Did you see the new bike Cladoo set up in the photo gallery? The whole kit and kabootle, switches, blinkers, big rear fender extension etc. Maybe someone up there with a new bike would want to unload some of that stuff?
Skidad in MA
Good idea Skidad.
If any of you Hosers would like to sell your signals and handlebar controller, I'm interested.
I have the license plate extension, and I can easily find the headlight and taillight which most of you probably want to keep.
Thanks,
Josh
When I bought my 06 300 the dealer told me I f I wanted all the euro road stuff that he could get it for me. NH doesn't require all of that stuff to plate your dirtbike so I did not bother. He said it was all plug and play. don't know if they changed the wiring harness much between 06 and 07. I'd go with the factory gasser stuff.
I would have but I just sold a DE300 to a guy and he wants all the stuff on it. So guess what I am doing today?
Good idea Skidad.
Thanks,
Josh
Cladoo,
I'm no hurry. Please keep me in mind if you come across some more parts I need.
I guess I forgot to mention the horn also.
Do you know if I just feed power and ground to the handlebar controller, then the horn and signals plug into the controller?
Thanks,
Josh
I was looking on my 07 and the main wiring harness doesn't have all the connectors. It's rather amusing the bike has a front and rear brake switch but nothing to plug it in to.
I'm assuming GG is doing the same as KTM and has a stripped down wiring harness for the USA 07 and a full one for everybody else. I called Mark at GoFasters and he had no idea what I as talking about even though there's 2 different part numbers for the main harness.
I'm with you Josh, I would rather use the factory bits like I've done on my KTMs.
If anybody figures out a source I would also appreciate it
Ud_Luz,
You, like me, have a US spec "DE" model with the simple harness. The "world" spec bikes that everyone else gets have the full harness and all the switches, connectors, as well as the larger ignition. Euro street legal. Some early '07s came here this way. Find a guy that wants to trade, that hasn't hacked on of stripped the harness. There is a lot or wire on the "world" EC bike that most US racers don't need or want.
Look at your bike, if the stator wires exit toward the front at about 10 o'clock its a 2K-2, if they exit toward the rear on the flat of the cover its a 2K-3. Late '07 my guess is a 2K-2, but some early ones came with a 2K-3 and the DE harness.
BTW, I guess you havn't done so since you asked this question, but remove the ignition cover after a ride/wash.
I've got the 2k-2 also.
Why should I/we remove the ignition cover?
GMP said:
2K-2 wires exit 2 o'clock, 2K-3 10 o'clock. Some of the early '07s came with 2K-3s.
OK, which is it?
i have it now!
!!the front circuit must be closed before the rear can be!!
yellow is basic ground(explain later)
in the front under the number plate, there are: 2violet,,1yellow,1yellowgreen
violet/ yellow is the running light, violet/ yellow/grn is head.
in the rear there are 2 parts
first harness is white, yellow green, violet
white=brakelight, y/g = ground, violet=hot
the second part(which i chose to cut into, since its not part of the chassis harness) i found tied up in the airbox has 2 parts
1) brown/black, im not sure what this is, i didnt use it
2) 3 prong with green, black, and brown.
green= brake switch, black=ground, brown=taillight
i hope this is helpful, it took me a while to figure it all out, since all the schematics i can find are black and white+low res
