E Start Issues Wiring GG EC250 2019
tholt2
Hi guys,
I'm really struggling to get any sign of life from the e-start, not even the audible relay 'click'.
I've tried everything I can think of, being:
New handlebar switch - continuity is okay
New starter motor - tested prior to fitment and it spun fine
New relay
Upgraded battery wiring and better earth connection
Battery is all okay and is the upgraded one with sufficient CCAs.
Not sure what I'm missing - but would be grateful for any help!!
Could it be the diode module? How do I test this is okay?
I have a fairly simple wiring set up as I disconnected from the wiring harness all the lights. It's starter switch and killswitch only.
Not having ready access to a schematic, I would expect that you should be getting power from the battery to the magic button, and then when pressed to the relay (or solenoid) which should give you a click.
Once the relay is clicking it should be powering the motor.
Sounds like something awry with the wiring to the relay.
