bluespark
Hey all, I am the happy new owner of a 2011 EC 300 e that I brought home yesterday. I was going over the bike checking things out and just looking it over. The bike started on the 1st kick when the owner showed it to me, and the e-start worked great several times after that while I was going over it.
The PO had taken off the headlight and handlebar switch cluster. I went to re-install the head light and found several scenarios. I Plugged in the round connector on the back of the headlight and then connected one of two available two pin connectors into the other wire coming from the headlight assembly. When I plugged in the first 2-pin connector the headlight came on with the bike not running. I then tried the other connector and the HL did not come on, so I tried to start the bike to see if it illuminated.
At this point I hit the button and the starter made no noise at all. I unplugged the 2-pin connector and still no starter movement/noise. Battery still showed ~13v. I then kick started it, but this took 10 or so kicks.
I have not had time to look at the digital manual that came with the bike or any associated wiring diagrams, but was hoping someone here could shed some light on this. I am sure its something simple like a fuse, but I would like to get it fixed so I can try out my new ride this weekend!
