Ec 200 burns too much gas
Right, sorry. Focused.
Although I do note that your Fate line almost intersects your Love line, and the Head line presents as less angled than usual but the broken skin makes it hard to tell. I think you need to reconsider your moisturizer.
But change the float needle if in any doubt. PWKs are great carbs but they do wear and dribble. My mates GG emptied its contents in my van overnight. Had to throw the carpet away and drive with the windows down. Took 3 months until the wiff of gas was gone.
Do check that needle jet with a magnifier as well.
Sorry about the long delay. I?ve been slowly trying things to get my bike to run better and burn less gas. After cleaning the carb and adjusting the float height multiple times I still had no good results for making my bike run better. Just yesterday I was checking over the wiring and found a very loose connection on the coil (Attached image). I cleaned out the connection and pinched it on there better as well as replacing the spark plug cap. One of those two things seems to have made a big difference in the way my bike is run. Way less spooge and smoke out the exhaust and no hesitation throughout the power range. Today I will go for a longer ride to test my fuel consumption but so far I think my problem is mostly solved.
