EC 250 2008 footpegs
mrfreezer
Hi guys.. I have really bent and few time welded foot pegs on my 2008 gasser. I have pair of RMZ foot pegs with mounts. I want to cut old footpegs and use those from RMZ. Do you think is it possible to cut threads to frame or it would be better to weld it? I dont know if the frame on my gasser is hollow where footpegs are welded.
It would be better to weld it.
There's not enough material in the frame there to thread into.
Thanks guys.. That's exactly what I was afraid of. Will weld it... I than I can use good looking billet pegs frok ebay for few bucks 😂
You can use good looking billet pegs anyway. You just buy the Yamaha type. They will fit your frame (if the frame isn't damaged, that is).
You can use the bolt on foot peg mounts off an aluminum frame dirt bike.
Cut you mounts off and weld the mounts on.
Or you could weld on the later Gasgas frames' bolt-on mounts. I have bolt-on mounts on my 2015, I presume this is the same from 12 to 17.
Finally done... looks much stronger than stock pegs... and I made sidestand too when I was already welding
