Hi all, 1st of all Happy new year.
Ok I as had some spare time this weekend I thought it was time to down size my mates 2011 CC 300 to a 250 ,
It had always been very vibey ,so bad that it made your feet tingle , and could also feel some up/down free play in the main bearing on the flywheel side,
He has a S3 head kit (3 inserts ) and a S3 piston,
It's all built back up, So we can Carrie out some measurement to sort out squish and compression ratio,
My 1st Gripe is that all 3 inserts appear to have the same head volume ,the only differences being the squish , What's that all about then,
This is where I'm at, at the moment just for a starting point,
.5 + .3 base gasket, this makes the piston 1.0 mm above the bottom of the exhaust port @ BDC, Will this make it flat on top end ? Should I add another .3
Carried out a CC check on the combustion chamber with the black insert, Squish is 1.35mm And it's 16 cc That's a UCCR of close to 16:1
These head inserts are a waste of money, They are nowhere near plug and play,
Carried out a compression check with a calibrated gauge and we have 225 PSI
Much to high.
So it looks like some head machine work is needed,Mybe something close to 20 or 21cc
May have well just machined up a standard 250 head,
How do my findings compare with anyone's
Also what sort of jet sizes. Needle type for the 250 set up. Temp 10-20 celceus
0-500ft above sea level
Thanks
V-tec
Much to high.
Thanks
V-tec
