jeez now my 06 300 is doing the same thing,after not riding it since november last year,it runs like the choke is on on the top end,it idles fine,throttle response is great,it just has no nut and really loads up,havent done anything to it since november. I started out cleaning the carb four times,but its seems like a very rich condition,so if anything was clogged wouldnt that lean it out? I then took off the air filter and tried it,then the pipe,heated it and burned any carbon to make sure there werent any blockages,same with the silencer,took off my P/V cover and made sure it moved when you revved up the bike,changed out the carb from my 05 200 and it ran the same,checked my ground for the voltage regulator and my coil wire/spark plug wire,and changed out the spark plug!! any more ideas??? I ended up preppeing my 05 200 with the carb from the 300 and raced that instead on sunday,but would still like to find out why it wont rev out at all
