Ec250 -12 CCK #1,PJ 40 main 170 slide 7?
andper
What do u think, too lean or too rich? Sounds and rides well.
Riding at 150m above sealevel and about 20celcius
CCK #1,
PJ 40 ,
Main 170 ,
slide 7.
So why are you asking?
Move the needle clip one position. Then the other direction.
Better or worse?
Any pinging noise?
Better or worse?
Any pinging noise?
Because im new to jetting and I wanted to know if you think of that. "WOW, thats way too lean" or "WOW, thats too rich" or ....
Started out with need in #3 , with some hesitation on throttle, which improved by moving it to #2 and even more to #1.
Still not satisfied with throttle respone right of idle tho
Those numbers sound like maybe a RB modded carb. My 2007 ec250 with an RB mod carb has 175 main, 40 pilot with the air screw 2.25 turns out (so could run a 38 pilot), CEK needle at #2, and #7 slide. Similar elevation and temp to you.
Okay, i live in Europe so I dont think its RB modded. Good thing the numbers doesnt look way off. CEK #3 is similar to CCK #1 right?
Pulled the plug and it was black. better a bit rich then too lean i guess, im sticking with this jetting for now
By "CEK #3", Motoman is referring to the specific groove in the CEK jet needle in which he placed the "Jesus clip"; the third from the top, or the middle groove. (Jesus clip is referred to as such, because when moving the clip on a trail ride and the clip falls into the leaves and dirt, it often prompts the exclamation "Jesus!". I learned this from a fellow rider during a trail ride in Idaho. :) )
Maybe change the order and talk to Jesus before you play with the clip.
