Just about to fit engine casing but noticed that the is 2 O-ring seal on out put shaft and also the sprocket seal.
I have pushed sprocket seal into casing but was wondering when I fit the metal bush with the two o-rings.
Do I fit bush and o-rings onto output shaft first?? Or do I fit casing with sprocket seal and then push the the o-rings and bush in afterwards????
I read the workshop manual but doesn't mention the 2 o-rings???
