If you have the 2K-3 which you probably do, there is a small locator insert in the upper slot of the stator to fix the timing. This can be removed and/or the bolt hole elongated 1mm or so for more advance. I have done this myself on an '03 250. Be carefull, especially with the more aggressive curve.
I'd look at the squish and jetting first, JMO.
