EC300 Gearbox oil
Standard oils are fine. Just make sure they have the correct rating that approves them for use in wet clutch applications.
That said, I always use ATF Type F transmission fluid.
In my experience Motul Transoil std makes the clutch drag.
Motul Transoil Expert allows you to kickstart in gear.
Lovely stuff.
I used to use ATF Dex II. Just out of interest do you know what the difference between the Type F and the Dex II is?
The friction modifiers are different. The Type F has less friction reducing modifiers, which results in a more aggressive engagement, than the Dextron/Mercon II/III.
