Hey Guys,
As of recent, the EC300 has undergone an SM conversion.
In the process I've changed the gearing and added a pipe system.
The bike is 2001 and is ridden in the UK, under 55 degrees F, and around 0-2500ft. The front drive sprocket is OEM still, and the rear is a 41 tooth. I weigh about 80kg.
Should i be changing my Jetting set up? I would like the bike to run a little crisper with the new pipe system.
Anyone got any suggestions as to what set up i should use? And what parts i actually need to buy and replace?
Thanks for the help in advance.
