rgranger
Ok, I had Less do my suspension: when I removed the spring it had some perches that set inside the replacement spring, it seems to have a bigger OD than the factory? it doesn't seem right that the factory spring would ride on the plastic adjuster without some steel buffer or something.
also, is there a replacement for the plastic adjuster ring.
and WTF is it with the plastic screws holding the side panels on! one head came off the screw before the screw came out. They could take some serious tips from KTM on side panel attachment!
Any help would be appreciated.
