My ’06 EC300 has some electrical issues which appear to be related. It is a stock Euro EC300 with higher output electrical system, halogen headlight, taillight/brake light, turn signals, odo/speedo and horn.
Here are the problems…
Above about 6000 RPM the ignition will intermittently cut out. It doesn’t do it all the time. The higher the RPM the more it tends to cut out. Reducing RPM brings the lights back to bright.
Above about 6000 RPM the lights start to dim intermittently. The higher the RPM the dimmer they get to where the lights almost go out. The engine runs fine if the RPM is reduced.
The tachometer records some very high RPMS when the system starts to act up. Max RPM recorded is 19999 which is totally unreasonable.
I am looking for some assistance in troubleshooting my electrical system and how to isolate the problem(s).
