ironcity
hello all, I have a 2019 Gas Gas EC 300. Just this last weekend my e-start switch stopped working, it was working fine up to that point. When I press the estart button, I do not get a click on the solenoid. So far to test everything, I have jumped the starter solenoid and the starter is working. I have bench tested the starter solenoid and I hear the click when I apply 12v to the terminals where the start button connects to. I have replaced the fuse on the starter solenoid. I have tested the start button leads for ohms when I press the start button and there is continuity. What I have noticed is that there is no 12v on the wire to the actual estart button. I'm assuming there should be 12v at the actual estart button on the handlebar switch cluster, correct? Thank you for any help.
