I agree with GMP on the point that you really don't need race fuel until your compression gets close to the 200psi mark. I don't think that running AV gas will hurt anything as long as you don't get it too lean which is true with any fuel. My only complaint with it is performance seems to change more with less of an air change than other fuels. I would avoid alcohol if possible for the simple reason that it absorbs moisture and becomes very corrosive once it's mixed with water. It does damage when your bike is parked in the garage. If I were in your situation I would consider buying fuel by the barrel in a quantity that you can use without it getting stale.
