Float Bowl HELP!
gasIdaho
I was taking my float bowl off to re-jet and my float came off with it as well as the pin and the other part(plunger?). This has never happened so I never paid much attention to how the assembly hooked up.
My question is how to re-attach this other part which I'm assuming regulates the gas flow into the carb. Does it just slide over the metal tab on the float assembly?
Yes. The loop on top of the plunger just slides onto the tab on the float.
Yep. Got her up and running. Classic situation. Good tunes and distilled liquids flowing. Pull off the float bowl, parts fall off and slide down into countershaft and linkage nooks. Good times......:D
