Both good suggestions:
Floats have been submerged - no bubbles or leaks, no fluid inside when shaken
I have checked, double checked and treble checked floats for fouling. I am sure floats are clear from both body of carb / bowl and also the brass overflow pipe.
I cannot dispute the fact that issue occurs when the float bowl is assembled, but given the positive valve operation during the water test I am more confident that the fuel shut off is probably ok. I was assuming the level is too high, but maybe not - possibly shutting off fuel / lowering the level is correcting some other fault...
It would be usefull to see a photo of the fuel level on a working bike - if anyone has one?
Thanks for suggestions guys...
