Anyone know if WP 48mm open chamber forks will interchange with the Sachs forks as far as clamp diameter goes?
I have a revalved set of 48mm's I'd like to try. I would have to use the KTM front wheel on the GG as well. The brake rotors are the same diameter as well as the caliper mount.
Side by side on each bike both the Sachs and the WP outer tubes look like they are the exact same diameter and length. They even have the same machine work and the same "step" down and parts by the fork seal area. Does the same company make both the Sachs and the WP fork tubes?
