skid jackson
gotta change overthe fork seal on one of my shivers (06 300)
looked over the zoke manual ...
doesn't look overly complicated
any tips or tricks I should know about??
I've read that you can run a shim around the inside of your fork seal to clear out any dirt that may be causing the leakage. it started leaking while riding on a indoor mx track. I believe my slap down landing techniqu was the culprit. Assuming I did this and there was dirt in there and the shim got it out of the way. Would pushing the fork up and down against floor provide enough umph to let you know that it was now sealing? Or would only find out after you took it out and slammed some good roots and rocks??
