Fork sliders for 45mm Marzoochi
rvangeel
Does anybody know of a fork slider that fits on the 45mm Marzocchi forks? Mine are rubbing and wearing to the point that I am starting to worry.
I just recently installed the SKF fork seals. Unfortunately they don’t have any mud scrapers for the 45mm fork. Great products though. I also installed the seal and spacer kit which is simply amazing.
Seal savers would do the job. I also had some luck with using zip ties when I had those forks. The fit that groove very well and are easy to change every few rides.
Italian husqvarna had a bolt on sleeve on there 45 mar to protect the alloy leg . iv just rebuilt my 05 45 had to shim the slide bush 001 th on the rh and 002th on the lh leg. look on ebay shim steel
