If you have a stock bike you probably have a large squish measurement and you will pick up low and mid range power with little loss in top end if you use a thinner base gasket. If you have any ridge at the top of the cylinder you do not want to use a thinner base stack than what was in there previously because of possible ring snag at TDC.
While the factor stacks gaskets with few issues, I prefer the single gasket over a stack. Another option is to use some spray tack to glue together multiple gaskets.
