ricardo cabeza
I just picked up a de 200  and after 1st ride I was not happy with the way it ran! lets jst say the jetting was way off and it would not idle.
with the bike cold the choke was not effective. this tells me the pilot was to riich so I dropped from a stock 45 to a 35 and the bog at 1/4 throttle w/a slight load on the motor was gone and the choke actually acted like it should!(I ride at 1500' to 3000')
BUT it did not effect the idle, so out came the carb(boy was that fun)with the carb on the bench I put the slide back in and put a small flash light in one side and examined how much the idle screw raised the slide. lets just say that it did not affect the slide height untill the very last 1/2 turn and then it only raised the slide approx 1/2 of 1 mm. Now just to let you know it DOES take actual air passing through the carb to activate the idle circuit!
I believe the japanese guys at keihn are screwing with the spanish guys at gasgas by putting extra long springs behind the idle screw SO take out the spring and cut a couple of coils off and reinstall(yes this does raise the springs rate, you wll not be able to turn w/fingers)
TaDa it idles!!!!!!!!!! next week I will try a power-now, it made a huge diff. in my 99' ec 200 and yeah I know, you guys w/ 300's probly won't notice a difference but do you guys really need MORE low end?
		 I think most are not up on their spanish here.  Cabeza = head.  I think you can figure out the rest.
