Well, how many of you have managed to put a hole in your tank? Well, be honest... Mine does, I got if used and I hear this is fairlly common? Any help would, help! Thanks.
I have heard of some folks having this problem. It is not very common for the tank to leak - but it does happen; It is common for the threads to pull out of the mounting holes... Search on "tank inserts" and you will find the solution to your problem. There are also some metal inserts that can be had from mcmaster-carr that will make the mount more solid.
