GG 250 4stroke
gasser
Last Tuesday I saw the new 250 gasaha 4stroke at a nearby dealership (Sportcycle KTM in Maryville, TN). The 2010 gassers are beautiful. The bike was awaiting an exhaust pipe which I think Dave said was being made by FMF. The bike has a hydraulic clutch and costs $8000.
You're lucky to even see one of those as only 6 made it to the US in the first container of 2010 bikes:rolleyes: :mad:
what can you do about the dinky gas tank??
did they get something bigger on there
Apparently it holds around 2 gallons and Dave seemed sure that it was the same as the stock 450 tank except no fuel pump. If that is the case Clark could easily make their oversize 450 tank with the fuel pump hole left uncut.
250 4T Hydro Clutch
How did they get the Hyd clutch on there? Sounds like a fun machine.
It's not unlike the Magura Jack clutch kits that have been out for a while. You bolt on a master and slave cylinder and then actuate through the last bit of cable or the arm that is exposed.
Here's a shot from that elusive and rare bird last seen at the dealer show.
Yes the 250F at our shop has a bolt on hyd clutch, lights and many extras.
The guys riding all the National Enduros run the 250F and they get 31 mile per tank, the clarkes 450 tank Im told fits this bike and should get over 40 miles in tight trails. The bike is small and light just a fun and easy bike to ride.
