good source for gaskets?
Adam500
Need a inner and outer clutch cover and water pump gasket for my 06 300.
Can I get them aftermarket anywhere?
Still haven't found a fast an easy way to get OEM.
If you are in the States, contact Bob Piper at North Tahoe Motorsports. He has custom gaskets cut which have a metal center. Very robust (and reusable) gaskets.
Are those custom gasket ? The new version of the GG OE gaskets come that way with the metal center and rubber outside.
I'm in the states.
Went to the cometic site and I can't figure out which on they are calling the inner clutch gasket. They have multiple "center gaskets" not what I would I would call the inner clutch cover. They have 2 listings for a clutch cover. Is that the outer?
Cometic provides the GG OEM part number so you can do a simple web search to see the gasket.
I believe they are a composite gasket without metal. I have used them and they work great.
