Graphics install
Wbdisco
Does anyone have a picture of their shroud graphics on a 2011? I order new ones but I?m not sure how they line up on the contours exactly. Thanks
Brad
Here is mine using graphics from Motocrosscenter.com or you can watch how I did it in my video here: https://youtu.be/bsro6fyzXSQ
attachment.php
Spray Windex on the graphics before you install them, allows you to move them around.
Use a heat gun on the contours.
I?ve used the windex trick before, I was just not sure how the decals fit on the contours. The kit came in multiple pieces and I wanted to see how they were supposed to line up. I did get the stock graphics, not the six days
Got them on last night. Definitely didn?t go as good as I hope for. The shroud graphics I ordered were about 5 separate decals per shroud. Looks good from a few steps back, but there are a few air bubbles that I couldn?t work out. Surely they will last for a little while. Also, they were not new plastics so I?m sure that had something to do with it.
Nice.
You can take a razor blade and cut a small slit where the bubble is and smooth it out. Won't be able to tell.
Some people say use a pin. But that leaves a raised surface which you will still see.
