Graphics install
Wbdisco
Does anyone have a picture of their shroud graphics on a 2011? I order new ones but I?m not sure how they line up on the contours exactly. Thanks
Brad
Spray Windex on the graphics before you install them, allows you to move them around.
Use a heat gun on the contours.
I?ve used the windex trick before, I was just not sure how the decals fit on the contours. The kit came in multiple pieces and I wanted to see how they were supposed to line up. I did get the stock graphics, not the six days
Got them on last night. Definitely didn?t go as good as I hope for. The shroud graphics I ordered were about 5 separate decals per shroud. Looks good from a few steps back, but there are a few air bubbles that I couldn?t work out. Surely they will last for a little while. Also, they were not new plastics so I?m sure that had something to do with it.
Nice.
You can take a razor blade and cut a small slit where the bubble is and smooth it out. Won't be able to tell.
Some people say use a pin. But that leaves a raised surface which you will still see.
