Hummmmm. The online manual says it is permanently set to KPH or MPH. Bummer.
From page 22 of the manual downloadable from Moto Center:
https://gasgaspartshouse.com/tech
When the motorcycle is started, the display panel is activated and remains on.
The dashboard will display the normal mode and will be on for 30 seconds if no speed pulse is generated.
If one or both buttons are pressed, the dashboard will display normal mode and will last 30 seconds if no button is pressed.
Speed
The speed or speed units are permanently displayed in km/h or mph with a range of 0 to 199 in both cases.
Odoometer
- To display the breaking-in time or km press sET < 2 seconds.
- To change units press SET > 10 seconds.
- To display the total press mode < 2 seconds
Route a - Route B - Total.
- To enter the clock mode press modE & SET > 2 seconds.
- To enter the wheel length mode press mode > 10 seconds.
Adjustment push-button
Clock format:
if the units are in km. ----> 24h. if the units are in mi. ----> 12h.
- To increase the hour digits press modE < 2 seconds.
- To increase the hour digits quickly press modE > 2 seconds.
- To increase the minute digits press sET < 2 seconds.
- To increase the minute digits quickly press sET > 2 seconds.
- To exit the clock mode and save the values press Mode & SET > 2 seconds.
- pressing no action > 10 seconds will exit without saving
changes.
route a and route b
- press modE < 2 seconds to display the dashboard.
- press sET < 2 seconds to display the breaking-in time or km. - press sET > 2 seconds to reset.
Configuration for Wheel Lenth
- To change the wheel from 2100 - 1811 press mode < 2 seconds.
- To exit the wheel length mode and save the value press modE & SET > 2 seconds.
-To exit automatically without saving changes, press no action > 10 seconds.
