I just replaced the the combination ignition, lighting coil in my 05 MC250 with a Moose(made by Electrosport) unit with 60w lighting.
I marked the stator plate with scribe marks to put it back the same, but it could have shifted some. I now have trouble starting the bike, hot or cold, I have to kick it very fast and it then runs and idles perfect. When I do a spark check, it is a good looking blue spark, although I have seen stronger.
I'm assuming that the problem is probably with the spark timing, although I did change silencers about the same time.
Can anyone tell me how to check/set timing or is my best bet to just turn the plate a hair at a time until it starts easily? Would I retard the spark for easier starting?
Matt
Matt
