I'm going to launch into the unknown that is the engine of my ec200 to check out the condition of the top and bottom-ends and send the head off to have the squish sorted out. The bike has gone well in the 6 mths I've owned it and I've got the jetting pretty close but I want to check where I'm at for piece of mind.
I've rebuilt 2 strokes from scratch before, but they were old school air cooled engines and i just wanted to check a couple of things regarding getting the engine set up correctly before measuring the squish.
1. Piston/exhaust port height. From what i understand the optimum position for the piston is flush to the bottom edge of the exhaust port at BDC?
2. Piston/ring/cylinder condition. Again, my experience is with older engines, what tolerances should I be checking re piston/ring clearance and what should I be looking for with a plated bore with regards to wear and tear ? If I need to replace anything obviously I want to do it before I measure the existing squish.
Thanks in advance.
Thanks in advance.
