Header pipe rubber mounts?
GGRider01
I'm trying to find a cheap source of these little mounts with the rubber vibration dampening bit sandwiched in between.
You can buy them from vw/audi 1.9tdi engine cover mounts. also opel vacuum solenoids are mounted with them. Should cost you 1-2 euro, but you have to fabricate your own plate to fit them
Ok, found crossover between KX250s for the rear pipe hanger BE25626004 but cannot find any crossover for the front, which is BE25626007.
I'd hate to place an order from Spain for such a simple little thing. Might just find a suitable chunk of rubber and drill a hole through it. I noticed in the Scalvini pipe review it's bolted straight to the frame with no dampener.
KTM 2T range man.
Same same same and much more resilient than the GG ones which are lucky to last a week or two at best.
That isn't the same style as the 2000 wears which looks like this
You can get those from McMaster Carr, assuming you are stateside. Just pick the thickness as well as the bolt size and you are good to go. Isolation dampers, I believe.
If I brought one of these into any shop in town they'd give me a puzzled look. :mad:
I always think about the kind of things I'd carry if I owned a shop.. Needles and jets galore. Actual parts, not this chromed garbage everyone here is selling. It's the Rocky Mountains.. dirt bikes everywhere. You'd think someone would carry needles. Not even the Yamaha dealer carries needles for their Yamahas!
