dirtrider0129
I bought a 2003 DE 250 last week. the bike runs fine, but the headlight doesn't work. The previous owner said it didn't work, but he didn't have it hooked up so I couldn't see for myself. there are 3 sets of wires behind the headlight, a yellow and white, a yellow and purple, and a purple and yellow with green. I've tired to search this forum to see the purpose of each wire and the only helpful thing I have found was the electrical schematic on headlight and horn tech article. I saw that the yellow wire was the hot wire so I hooked a multimeter up to it and a ground to see what kind of voltage I was getting. I started the bike and the multimeter only read .4 volts at idle and about 1 volt when giving the bike some gas. I checked all of the connections and everything was tight. What could be wrong. I'm assuming that the ignition is good as the bike still runs, so that only leaves the regulator to be at fault. Is there some test to see if the voltage regulator is bad or am I going about this whole situation all wrong?
