kingsizerizla
Help, changed seal and oil and filled to 135mm air gap. cannot bleed out forks Raised and lowered fork tube through its stroke, no noticeable air. raised and lowered damping rod through its stroke, but only getting resistance, ie damping on the very bottom of the stroke, say last two inches. Here you can feel the resistance and oil spews from the top of the damping rod, but not through the entire stroke.
Has anyone else come across this problem, or has anyone any idea as to what I may be doing wrong??
It should be a straight forward task.
IT,s a 99 ec300 with right way up forks. Thanks in advance to any techies that can put me right
