Stefan Baele
Bike year & model = 2001 enduro ec300 (2stroke)
Temperature Celsius = 0 - 30
Elevation =0-1000meter
Main jet = 182
Pilot jet =40
Needle & notch =n1EF notch = clip on highest point( needle lowest)
Air screw setting =2,5
Throttle valve/slide =7
results: from 0% to 40 % trottle the engine responds well .
if i go from 20a30 % trottle to WOT the rpms goes up but... it takes a 2 or 3 seconde to reach max rpms !it s like i should pull THE chocke a little bit up when i open THE trottle
when i close the trottle then and open it again right away,then it works Great,straith to max rpms.if i let HIM idle for 15 Seconds i got THE same problem again..
i gues he is to rich ???
Sombody Any suggestions for my what i should change first?
Pilot jet ?
I tryed THE needle clip 1 groove down but That is even worse
The owner before me did trial tracks with this bike..
Thanx and sorry for my bad englisch.
From Belgium
Stefan
Main jet = 182
Pilot jet =40
Pilot jet ?
From Belgium
Stefan
