The ones on the left are two stage reeds the top peddle is smaller than the bottom so it may be an optical illusion. I would take them off an look at the edges and mating surface. If they have crack or if they are not smooth on the mating surfaces, you should replace them. If you are in a bind you might be able to flip them over so you have a new mating surface.
