GMP
Active member
Girard posted a link to this awhile ago. (www.aluminumrepair.com) I bought a lb. of rods to try. The stuff works awesome! In ten minutes I fixed a worn out brake pedal buy filling the hole and redrilling. All you need is a Propane/Mapp torch to fix anything like this you might break on a bike. Guards, levers, subframe cracks, etc. Supposed to even work on cases that have oil impregnation, where Tig is a big problem. Check out the video, with the lap joint being beaten with a hammer and not breaking. I replicated that tonight and its no BS. Opens up doors to fix things that would previously be junk, without a big $$ Tig welder. Good tool.
