I'm not having much luck with it at all  ... I sorted out the oil leak I had, went out on my bike a few weeks ago with no problems. Went out last Sunday and the bike locked up on me in second gear, and it was quite a push back to the trailer!
... I sorted out the oil leak I had, went out on my bike a few weeks ago with no problems. Went out last Sunday and the bike locked up on me in second gear, and it was quite a push back to the trailer!  (at least I could take it out of gear to push it)
Anyways, I took the right side off as I thought the kick start gear had popped off -hoping more like.... but no turns out that's fine and looking up the exhaust hole it looks like the piston is scored to hell.
Anyways I decided to put it back together and leave it for a while... I'm a bit baffled where this white washer/seal goes does it push into the case then the other seal next to it on top then the impellor?
On the manual it doesn't show a white washer/seal...
Also the fact that they seem to be extinct and a lack of parts available for them is a reason why I'm hating it atm...
Don't suppose there are any non GG engines that fit in an 2001 EC is there (I can't even find a 300 engine!)
 (at least I could take it out of gear to push it)Anyways, I took the right side off as I thought the kick start gear had popped off -hoping more like.... but no turns out that's fine and looking up the exhaust hole it looks like the piston is scored to hell.
