Jakobi
Well.. well.. First time in forks and I was doing a simple and straight fluid change only. All was going well. Measured the stock air gap at 130mm. Bit higher than I though but oh well. Thought I'll make a small change only. 135mm. Yep sweet. All good! Go to put it back together. Running smoothly until...
Go to test the rebound clicker on the first fork after assembly. Its not working right. Removed the top cap again and cracked the lock nut. The cap backs off and the clicker is still sitting there in above the damper rod. Threads stripped
I expressed my frustration with a few common words before wondering how the hell I'm going to get out of this one.
I inspected the other leg and the only damage is to the brass screw (the clicker itself) which can be pushed out of the top cap. Essentially all I need is the new clicker, but will I be able to get one? or will this end up being than ben.
More than anything I'm disappointed in myself for doing this. Upon assebly I just failed to take enough care in making sure everything was lined up as it should have been. *sigh*
