No sealer needed, but you might want to do this if you plugged the 6mm hole in the bottom of the case. The hole will let water in. Otherwise you can vent the hole up to your airbox, then fully seal the ignition cover (including the vent slot).
Extra gasket thickness creates more play in the estart gears if they are too tight. This depends on crank position and assembly tolerances.
