ignition key
seb421
Hello would it be possible to put an ignition barrel on a 2004 EC 300
i've got one kicking about from a Honda VTR1000 and wondered if it would be possible to stick it behind the headlight
thanks guys
You will need to "map out" the functions of your switch. The stock GG switch has two operations. With KEY ON on it passes power to other devices. With KEY OFF it connects the black/yellow CDI wire to chassis ground (green/yellow wire).
