Ok, hello guys!
So my original problem was that my lights were bad, they got only 7 volts. I traced the problem to my stator, so i bought a new one from electrosport.
Once i got my bike running again, i noticed that the lights were no better. Anyways i thought i'd take the bike for a test run. Well i got 2 miles away and the bike lost its spark. Thought it was the spark plug.
Well it was not and after 5 hours of searching for the problem, i found it. Its the stator or flywheel. I tried if i got spark with my friend's magneto. We connected the wires from his stator to my cdi and hit the kick start. I got the spark.
I tested the impedances of both stators and they matched. Also the timing thing's impedances matched. That's wierd. Primary winding gave 0.8 volts when kick start.
So what do you think? A brand new stator works for 10 minutes and dies? Ground problem? Flywheel problem? Oh and i think the lightning won't work because of ac regulator faulty. I've gone through all the wires and everything was fine. They all get their grounds and there is no resistance between the lightning system and the lightning coil
Forgot to mention, its -08 Gas Gas SM125
Thank you for reading
