I have a question about the proper way to install new bearings in the rear wheel. My question has to do with the gap that exists between the outer races of the two bearings and the bearing spacer.
If the design is such that a gap exists between the outer races and the bearing spacer, what provides the stop when installing the outer bearing? Typically you seat a bearing's outer race firmly against the bearing pocket (just like the smaller, inner bearings). But in the case of the larger bearing you can't (and wouldn't want to) tap or press it in until the outer race was firmly seated; to do so would mean you'd somehow managed to press the outer race in far enough to pinch the bearing spacer between the outer races of the two bearings. Which of course would result in significantly side-loading the inner races of the two bearings and even transferring force via the internal spacer to the brake-side bearing.
Obviously to do this you'd really have to "go to town" wailing on that outer bearing's outer race. But the question still stands: what provides the stopping point when seating the outer bearing? If you luck out and drop a cold outer bearing into a hot hub and it comes to gently rest against the bearing spacer, great. But you're not guaranteed that's always going to magically happen.
