Interchangeable parts what years?
RockJunkee
School me on what parts are interchangeable on 18 and 19 GG 250cc and 300cc
What years are plastic fit? Do 17 and earlier fenders fit? Pretty sure shrouds are a no.
I found that a ktm chain guide fits my bike.
I also have an excel a60 ktm rim laying around, will this lace to my gasgas hub?
School me on what parts are interchangeable on my 18 250cc.
Earlier model plastics will not fit up to the 18+ model years. You should be able to buy plastics for the 18+ bikes from Reiju through US dealers soon.
No, the KTM rim will not lace up the Gas Gas hubs. Not sure if it could be "made" to work. Others may know..
Sprockets for earlier model huskies and some other brands (Sherco? Beta?) will work on the Gassers.
Sharp looking bike!
I hope this helps.
What years are plastic fit? Do 17 and earlier fenders fit? Pretty sure shrouds are a no. :
Rear no, front may not match up with numberplate/headlight shell.
I also have an excel a60 ktm rim laying around, will this lace to my gasgas hub? :
only way to match it to a GG hub is to weld shut every other spoke hole on the hub then redrill it at the opposite angle(front to rear angle not side to side)
Kickstart lever - some Yamaha models
Front sprocket - All years 99- 2019 interchange on 2stroke enduro models excepy the 125 which takes a 125 yz yamaha
Rear sprocket - not the vintage huskies but the the years just before ktm took them over. 90 -93 250/350 Suzuki drz "S" model will fit (must be the "S" model) Rocky Mt has them in 43 and 49 tooth steel for about $20
Doc, I believe all of the newer KTMs have the same mounting points for the chain guide as the 18-19 Gassers. My buddy has a 2020 KTM 300XC and when he bought the Bulletproof Designs chain guide swingarm guard, the part numbers on the packaging showed that it also fit our bikes and I think even the newer Shercos.
Yamaha upper and lower shock bearings fit. Wr yz same part.number on allballs or pivot works website
Doc it's on t.m.d design website I think its 8>16 8 could be wrong though. Also not sure if the ktm changed in 17>21?
Sorry for the late answer!
Thank you for your reply, much appreciated. That sounds good, really good as they are easy available :-)
Thank you Junkee, in the meantime I have got linkage bearings from AllBalls and the kit contains the lower shock bearing. But it is good t know that the Yam parts fit.
Rear OEM brake pads are the same as OEM Yamaha part# 5UN-W0046-60-00.
Front OEM brake pads are the same as OEM Honda part# 45105-MY6-415.
