Part-Out 2010 300 and 2009 200
Updated 10 23 16
All prices do not include shipping. I think (and hope) that my prices are reasonable. I don't want to make a fortune off this stuff, just a fair deal for both parties......and I want it out of my garage
2009 200 50hrs on the bike. Parting-it-out due to the motor attempting to commit suicide.
Send me a PM or Email (preferably with the part you are interested in and your phone # ) and I'll gladly text pics. Texting is simplest for me.
Engine-Bottom End (including crank/excluding clutch lifter rod/excluding stator and flywheel) 09 200.
$150
Pipe OEM. One small dent (09' 200)
$100
New/OEM Water Pump Seal Kit (10' 300 )
$10
45mm Zokes (09 200)
$300
Oversized PV Cover- this is the one machined by the guy on this forum. It is two separate spacers, uses OEM Cap.
$40
Sachs Shock. (09' 200) Sprung for 200lb rider weight. Valved for rocks/very soft. 09' 200
$150
Triple Clamps. Top Clamp is the GPR Stabilizer Mount Clamp Includes Collar/Pin $150. (09'200)
Triple Clamps OEM (10' 300)
$70
Wheels (front and rear) 09 200. $300. One small dent to rear rim.
Wheels (front and rear) 10' 300 $300
09' Plastics OEM.
$50
OEM Radiators. (09 200')
$150 (set)
Plastic Frame Guards (just above pegs) 10' 300 + 09' 200
$5 each
Front Brake complete with lever (09' 200) $150
Aluminum Skid Plate $40 (09' 200)
Clutch complete, MC, Slave, Lever and Line
$100 (09' 200)
OEM Tank with Cap and Petcock. (09' 200)
$50
Carb OEM. Jets, Needle, (no cable or throttle body) $100 (10' 300)
Carb OEM. Jets, Needle, Cable and Throttle included $140 (09' 200)
Subframe (metal portion only, no plastic/airbox etc) 10 300 $150
Frame with Title $200 (09' 200)
Swingarm- has defect where a bolt that was too long (installed by yours truly) wore into the material. Bearings and Seals are new $50 (10' 300)
Airbox $ 20 (10'300)
Full Linkage $100 (09' 200)
TwinAir Air Filters (1) -used but life left in them $5 each
OEM Chain Guide $5 (09 200')
OEM Bar Mounts $10
Rad/Engine hoses $5
Bucket of Bolts. 75% of the bolts, nuts, fasteners, etc. Basically all the bits left-over after the part-out
$40
Wiring Harness with Stator $250 (09' 200)
Sicass Dual-Sport Lighting Kit. LED rear turn signals, LED front hand guard turn signals.
$200
New Rear Pads EBC $ 10 ?
Do you have a kill switch with a green earth and black and white positive?
Disregard...I have solved my issue
Parts
Hey Husley can you give me a call when you get a chance I lost your number wanted to touch base with you.thanks Sam 1 336 380 1368
Updated 11 12 16
$100
$10
45mm Zokes (09 200)
$300
$40
$150
$70
$150 (set)
$5 each
$100 (09' 200)
Cylinder- (No PV) 09' 200. It most likely needs to be re-sleeved or coated (nikasail or what ever its called). $30 (09 200)
OEM Bar Mounts $10
Rad/Engine hoses $5
$40
$200
UPDATED 11 27 16 HAPPY TURKEY DAY!
$100
$10
45mm Zokes (09 200)
$300
$40
$150
$70
$150 (set)
$5 each
$100 (09' 200)
OEM Bar Mounts $10
Rad/Engine hoses $5
$40
$200
PRICES REDUCED
GET THIS STUFF OUT OF MY GARAGE!!
UPDATED 12/30/16
HAPPY NEW YEAR!
$60
$10
45mm Zokes (09 200)
$300
$30
$100
Triple Clamps. Top Clamp is the GPR Stabilizer Mount Clamp Includes Collar/Pin $100. (09'200)
$50
Wheels (front and rear) 09 200. $250. One small dent to rear rim.
$100 (set)
$5 each
$80 (09' 200)
Carb OEM. Jets, Needle, (no cable or throttle body) $80 (10' 300)
Carb OEM. Jets, Needle, Cable and Throttle Body included $110 (09' 200)
Frame with Title $150 (09' 200)
Full Linkage $50 (09' 200)
OEM Bar Mounts $10
Rad/Engine hoses $5
$40
Wiring Harness $100 (09' 200)
$100
PM sent
Im interested in the plastic oem frame guards. If they are all the same shape I'll take the lot.
