Hey all,
First up this is my first post of this forums so please take it easy on me..
I am in Australia.. I have recently (2 months ago) purchased a 2002 GG EC250.. Bike is fantastic and rides really well but had been electrically stripped down to the basics for racing purposes by the previous owner..
Here's a few pics from when I picked it up:
I wish to re-set it up as per factory with headlights, brakes, indicators so i can road register it for bush riding purposes..
I have done lots of searching over this forum and found lots of informations, and guided by this information and my own electrical knowledge (pretty good i would say) I have managed to fully re-wire the bike as per my below diagram..
Now here is my issue.. When I measure the AC voltage coming from the generator on both the Low power (Yellow) and high power (White) to ground i get varying voltages from 10vac (cold idle) to 40vac (warm revving), but as soon as I connect either of these wires to the bike loom main power feed my voltage goes to 0vac and none of the lights or anything work but the bike runs fine..
I have fed a 12VAC power source into the system at the point marked on the wiring diagram with a Pink circled 1 and the chassis and all the lights work as they should so i am confident with my wiring..
I have measured the resistance of the lighting coil/generator and it seems to be within the spec of the service manual i have..
Basically pulling my hair out now trying to think of something that it could be but yer I am hoping someone has some ideas on what could be causing my lack of lights?
Cheers,
Nik
Cheers,
Nik
