Is a full rebuild worth it for a 2008 GasGas EC300? (Cylinder + Piston)
hello everyone
I'm at a crossroads with my 2008 GasGas EC300. It's time for a major engine overhaul, and it looks like I’ll need to replace not just the piston, but the cylinder as well (or at least go for a re-nicasil).
I like how this bike rides—never rode another 300cc to see if its different than mine..—but I’m concerned about the age of the bike. By the time I finish the top-end, bottom-end bearings, and seals, the investment will be significant.
Resale Value: In your experience, does a 2008 model with a "fresh" engine actually hold its value, or am I better off selling it as-is and putting that money toward a newer KTM or Beta?
Reliability: Are there any known "deal-breakers" for this specific year that make a full rebuild a bad idea?
I mainly ride hobby/soft enduro, no professional racing. Any advice from long-term GasGas owners would be greatly appreciated!
P.s currently on 50 hours on vertex piston. Already got a new exhaust system fmf gnarly and turbinecore 2.1 i didnt like the sound of the stock one, and beside this got a vforce reed valve 3 , new carb and jets. New
Hydraulic Clutch Master Cylinder new seat basic things.
Thanks ! .
How many hours in total on bike? It's not only the engine that gets worn. How about the forks (what type?) and shock? All bearings in the chassis will need replacement sooner or later (steering, swingarm, linkage etc) if not done recently.
I'm all for maintaining older bikes, but I think it's a lost cause (economicly) if you don't intend to keep it.
I have had my 2015 EC200 for ten years and ridden it 500+ hours. I have used lots of money keeping it fresh and serviced in the bearings and suspension departments + the engine work like one big end overhaul and new pistons every 100-120 hours. I haven't added those expences up, as it would be quite depressing reading. But I have no expectations about a high resale value if I should conclude that my Gasgas days are over.
@Azlam denis : not sure where you live, but a new KTM300 XC-W TBi will cost you around USD$12k regardless of where you live in the world.
You've already invested in a decent exhaust system, reeds, and a new carb and the rest. You'll NEVER get all your money back for that on a sale.
A quick Google AI check shows that average resale prices are between USD$2,000 and USD$3,000.
Are you willing to fork out another USD$8k to USD$10k just for a new bike, or will that old bike last you forever if refurbished and maintained?
Consider that a new bike STILL needs new pistons, rings, cylinders and bearings at some point ANYWAY.
Hello, suspension is recently forks have been serviced marzochi front forks and the shock its still in a good condition, i dont know how many hours the cylinder has but i got the bik second hand since that i changed the front sprocket,carb,fork service, wheel bearings, jets, new golden chain, new vforce 3 reeds, added a fan on other radiator, clutch plates, and the piston has 50 hours currently but the cylinder is a D size and thats why im saying on the next top end i will need to do new cylinder or re nikasil..
I get your point about the money, but I’m not looking to buy a brand new 2026 model for $12k. My dilemma is whether it's worth putting more money into a 2008 bike or selling it as-is and moving to a newer secondhand model, maybe something from 2012-2016.
Even though I’ve upgraded the carb, reeds, and exhaust, the frame and geometry are still from 2008. I’m thinking that a newer 300cc (like a KTM, Husqvarna, or even a newer GasGas) from the 2014-2016 era might handle much better and have a more modern engine delivery.
If I sell my bike for $2,500 and add the $1,000 I would have spent on the cylinder/top-end rebuild, I’m already at $3,500. For a bit more, I could get a bike that’s 7-8 years newer. Is the performance and handling gap between a 2008 and a 2015 significant enough to justify the jump, or is the 2008 'old school' tech actually just as good once refurbished?
If you buy a KTM, buy the last of the CARB models (pre-2017). TPI models are picking up issues with con-rod and crank failures due to inadequate lubrication from the transfer port injection system. TPI was an interim design before they could get TBI in production.
Also, the pre-2012 e-starters were weak.
Since you asked for an opinion:
Based on what you’ve described, that piston should still be good for another 100+ hours. As long as you’re not riding aggressively or competing in extreme events, it should be just fine. These engines are built to last, even in God Jarvis hands.
I don’t think you need to change the piston anytime soon, and I’d only look into a cylinder repair if it’s actually necessary. I usually get more than 150 hours out of each piston change, and wear has always been minimal.
Also, how do you know you need to Nikasil the cylinder? Is that based only on the engine’s age, or do you actually know the current condition of the cylinder?
As for a full engine rebuild, it really depends on how long you plan to keep the bike. Personally, I wouldn’t do it — chances are you’ll want a newer bike long before the engine ever gives up, even if that takes a few years.
One tip: buy tools and learn how to properly measure piston and cylinder wear (around €100). Knowledge and the right tool for the job are some of the best investments you can make in your enduro journey.
Thanks for the advice, man! I definitely agree with you on the tools—learning to measure the tolerances myself is the best way to stop the guesswork.
Regarding the piston life, the main thing that has me worried is that I'm already on Size D, which is usually the last overbore for these cylinders. While the engine sounds great and compression is currently strong at 175-180 PSI, i have some aluminum transfer marks on the cylinder walls from a previous lean-running incident are always in the back of my mind.
I’m hoping the Nikasil is still thick enough to just clean up the transfer and throw another D piston in when the time comes, but being at the limit means there's no room for 'Size E' if it's worn out. For now, since I'm just riding fields and trails without hitting the rev limiter, I'll take your lead and just keep riding. If it starts and pulls like a beast, there's no reason to crack it open yet!
Cheers for the input!
Opinion piece...
I completely rebuilt and modified a '90 KDX200 just over 14 years ago. At that time the bike was already 22 years old. Was it worth it? To me it was! Loved that bike. Did the same with my '05 GasGas EC250. I would still be riding that bike if it hadn't been stolen. Did the whole process over again with a '98 KDX220 and my current '11 GasGas EC250R is being rebuilt now. Is/was it worth it? IMO, absolutely yes!
Anyway, there is nothing a modern bike will do better than your '08 other than have e-start (you can even add that IIRC) and better parts availability. That's it. I've ridden all the newer bikes (except TM) and I can tell you than unless you are a pro rider/racer you really won't notice the difference in performance if you have your current bike dialed in. Frame geometry hasn't magically gotten better and neither has suspension in the last 20 years.
Now, if it is you just want to get a "new" bike, I say go for it! Whatever makes you happy and keeps you riding! Just don't expect it to be actually better than what you currently have. Newer bikes have their issues as well and especially so if you buy used. You already know what your current bike has and what it needs. Just plan on sending the cylinder to Millennium soon to get it replated and it will be good to go for a long time.
wow
I really appreciate your take on this! It’s honestly refreshing to hear from someone who has owned and rebuilt multiple GasGas bikes. You’re right—the bike has a lot of soul, and knowing that a veteran like you still finds these older frames competitive makes me feel a lot better about my '08 EC300.
I’ve decided to keep it and go through with the rebuild when the time comes. Like you said, I already know this bike’s history and what it needs, whereas buying another used bike is always a gamble. I’m going to focus on getting it 'dialed in'—starting with a fresh top end and cleaning up the cylinder.
Thanks for the encouragement, it’s exactly what I needed to hear to stop overthinking and start riding!
Also , I want the bike to be a little more aggressive, do you have any tips on tuning the power valve on these older GasGas engines?
More aggressive? Man, my '05 was a beast!
Big thing for me was getting the carb jetting dialed in. I picked up a lot of power just right there. Otherwise, I would make sure the head squish is good and run an expansion chamber that is better in the mid-high power range. On the power valve itself, make sure it is adjusted properly first and, if that's not enough, you could always add a shim to the governor spring to make it hit a little harder.
I still have my 2011 EC 300 and it runs and looks great. I can ride it as fast as my 2022 Ranger 300. There are some things about my 2011 that I like better than the 2022. If you sell or part out your 2008 you probably will never find another one. These older gassers seem to be great bikes. I have a friend who had multiple new bikes and went back to a 2011 gasser. It took him a while to find one.
How could i adjust the powervalve? What jets did you have mate?
To adjust the power valve you must remove the power valve governor, disassemble it, and change out the shims that set the spring length. More shims, later but harder power hit. Less shims, the power comes in earlier but softer.
As for jetting, that was a long time ago and, because of what and where I ride, would not be the same for your bike and especially so being a250 vs 300. The 300's typical take smaller jetting than the 250's.
The only way to know what YOUR bike needs is to go through the jetting process step by step and it will be near perfect for the temp, elevation, and humidity for THAT day. If you keep an accurate log of jetting changes you dial in for various conditions you will get to where you just know what jetting you need for any given riding conditions. The jetting guide I follow is here: Jetting Guide and the best way to do plug chops: If you do plug chops... If you follow that jetting guide, and do the plug chops to verify, I guarantee you will get your bike's jetting dialed in near perfect.
Still enjoying my 05’ 300, contemplating cylinder or renikasil myself as I haven’t done a top end in a long time. 40 years ago I bought a new bike every year when I raced, keep them longer the older I get. I do keep the suspension and linkage much fresher, the motor has been ultra reliable for me. IMHO the bike is capable of going faster than I ride and still puts a big ‘Ol grin on my face every time I ride so I’m going to keep enjoying her.
Keep riding it. My 07 is took it apart for a leak in base gasket then the left crankseal went. Both times i measured the rings and they were only part worn. 300s don't work hard with normal trail riding. At like 10 years it was still OK after I'd rebuilt it. Crazy. Enjoy.
I saw On Any Sunday in Sydney in 73, and 5 weeks later bought a DT2 Yam 250 Trail. So 53 years later still trail riding an 05 300ec I bought new.
I really enjoyed reading this thread. I bought mine new in 05 it's a blue 300 with red plastic. Within a month I had regreased the steering head and linkages with a good quality Teflon grease. In 21 years I have only replaced 2 x Water pump seals and the fork seals once. Also the fork compression adjuster seal. Expantion chamber seals also. That's it. The head has not come off even once. Such a rock solid bike. I had the Ohlins serviced after running it in. So just preventative maintenance only. 50:1 Ester based synthetic oil.
Its true the PWK does require proper tuning. Especially the needle. They run way to rich and lack a real kick. Sort the needle and it just flys. I do crank up rebuilds on vintage 73 RD350, 78 Husky 360, Maico 440, KTM MC5 250 so its not a problem to rebuild. Just not necessary. I fit Keihins to everything including the RD. What can you say about these bikes. Just Awesome. I was at a hard enduro on the weekend and did not see anything I wanted lol ..... I would never sell mine. I turn 70 in a few weeks. Love this bike. When the time comes I'll put a new cylinder and piston on it 1k aud .... cheep for 21+ years. I'm only trail riding it. I'm retired. It does not get a lot of use but puts a big grin on my face every time I take it out. It's tuned to perfection now. No stumble of the pilot. I use it as an ADV bike. I'm too old to ride my 04 950 "S" KTM Dakar winner. It's too high, too heavy so I fitted a long Transmission to the Gasser, the max available, and can sit on 100kph heading home on the road. Usually 30+ km of tar. 13lt tank. What can't these old bikes do :) .... I might grab a new cylinder this year. Put it on the shelf. I fitted V-Force 3 also replacing the Boyson Reeds in 06-7. Love this bike so much. I can't remember joining this web site.This might be my first post. You guys have been great help over the years when I was looking for info. I'm an old 70's mechanic.
I guess I would like an e-start. I get left behind while trying to find footing to kick start it........
I do wonder is it possible to fit the Rieju e-start to early bikes? I can generally fit anything if it's possible to do so.
05 is the year they changed the engine cases and you could fit a e start. If you got a picture of the left side of your engine, I can tell you if it's possible to install the e start. If you have a 05+ engine, it's just 100% bolt on.
