I started the engine 30 sec before the video starts. Is it normal with so heavy bubbling? http://youtu.be/7Z-6RZk8kvg
Check and see if the head provides a smooth sealing surface for the O-rings. It is also possible that it is warped from overheating and you will need to get the head or cylinder mating surface trued to get a flat surface. If so it is a good time to check your head squish so you can get more power out of it at the same time.
Have you checked the stator side crank seal? Replace (not just clean) the pilot jet. Double, triple check the carb needle and position. I wouldn't expect the reeds to have this impact, but no harm in checking. Pay good attention to the manifold between the carb and reed block.
How's the transmission oil look?
Also, check the breather line for the fuel tank. Pull the fuel line off the carb and drain some fuel into a bowl/jar. Check the flow rate, and make sure the fuel is clean. A blocked breather could result in flow not being able to keep up with demand.
Could the float level be too low? That explains why it would run fine for a few minutes then go lean.
Sent from my iPad using Tapatalk
That was one of my first thoughts. I measured it to about 5 mm using this method.
http://www.allthingsmoto.com/forums...carburetor-float-level-more-commentary-13608/
