It is bone stock except for the clutch lever and possibly the gear lever.
It also has all the items that are typically missing on these bikes;
kickstand, grab handle, heat guard on exp chamber, crossbar pad, airbox, various bolts, etc., side panels, etc. etc.
I think it has relatively low hours on it as the engine still has decent compression and is (I believe) on the original top end.
Tank has some minor dents on the right side that can be easily removed. One small dent in the bottom of the expansion chamber can also be removed.
It shouldn't need a lot of parts, but will need a lot of elbow grease.
